Marker light mod
#471
Originally Posted by tmc104
No bulbs are good, I tested it on the other side thinking I my have blown it. I put all the wiring back to stock and still no turn signal. Funny thing is when I got up today and took the jeep out the light was working again. So I just don't know what was going on.
#473
#474
Did this mod last night and I love it. It's stupid how much a flashing light can bring happiness into my life.
Once I figured it out it was a breeze. I highly recommend this mod! Props to whoever the hell figured this out!
#475
Just spent 5 minutes doing the marker light mod. Easiest mod since flipping the rear view mirror. I second the post before me, when it worked I grinned like a fool.
#477
Originally Posted by bigchelis
I did the scorpion LED marker lights on mine.
Easy mod and I will try and post pictures for you later. Mine has the trimmed stock fenders so It was a must.
#478
The Scorpion side lights come with 2 wires
Just cut and re-splice to car wires. Then seal it however you can. Simple hand tools and you can go to electronics store and purchase some shrink tube to make it water tight and give it a little OEM look.
bigC
#479
The stock lights come with just 2 wires.
bigC
#480
Yes that is correct... cut the black going to the side marker and tap that into the outside white wire on the front turn sig. It does work as both marker and turn sig then. Durnig the day the side fender light will function as a turn sig and when the running lights are on the side fender lights will be solid until you turn on the turn sig then they flash. Have no idea why they dont come wired from the factory like this.
Pretty dumb.
Pretty dumb.
