Oil change
I used to do the amsoil with the dual filter set up and only pushed it to 12,500 on my Dodge Ram. Aaaannnnd, had lifters replaced. I still like the oil but it was just too much hassle to track it down. Signed up for the dealer element and still didn't care for the process. Switched to Mobil 1 and have had zero issues, in every vehicle I owned and currently own. I decided to try Royal Purple this weekend and on start up had the worst engine knock for a few seconds then gone. Switching back to Mobil 1 on the next change. It's not certified by Chrysler but I'm not concerned about that.
Mobil 1
Every 3k
Mopar filter (2012 JKUR)
Mobil 1
Every 3k
My 2012 jku turned 50,000 miles today. I change oil every 5,000 miles. Typically use penzoil synthetic. Have tried a couple others and honestly never can tell any difference. For filter I either go with mopar, or stp because that's what the places around me have. The dealer actually charges less for the mopar than autozone does for the stp. Going any longer intervals than what is listed in your manual will likely void your 100,000 mile power train warranty.
_______________
Depending on the operating conditions and health of the engine, many of the top offerings of the major producers can easily handle longer OCIs than most users "feel" is ok.
A top conventional or synthetic SN rated oil in an appropriate grade coupled with a quality filter will easily go the distance determined by the oil life monitor and provide more than enough protection for the engine (extremely dusty environments excluded, the OLM doesn't account well for extreme dust).
Quality oil, quality filter, follow the OLM without exceeding the maximums (time/miles) for warranty and sleep easy.
Started out with Castrol way back when.. (on other jeeps) then with the 99 we went to the Castrol syntec.. which later became known as edge.. Been using Edge ever since. Typically oil changes every 5k - 7K miles and as for the filters.. Voted in the what filter thread.. Bosch and we look forward to our next oil change very soon featuring the Bosch 3422 extended filter..
My wife's 2012 manual says 8k or 6 months max, my 2014 manual says 10K miles or 12 months max. I do both every 6 months as we don't hit the mileage. Of course, if the light comes on I change it sooner, as it is based on driving conditions. I would definitely not exceed that. Your manual should tell you.
I work with motor oil on a daily basis. Just finished another week long class on oil types etc etc. If you think you only have to change your oil every 25k your insane. Like another user stated. Oil is designed to pull and hold dirt, and grime. Also go and read the back of some of these bottles. Mobile 1 15k. Is a prime example. Should last 15,000 miles right. "Unless used in extreme conditions" go read those extreme conditions they will make you laugh. Extreme conditions are daily driving plan and simple. 3-5k in my opinion is when you should drain your oil. Even synthetics. Synthetic oils are engineered so that the molecules are uniform and flow better. Doesn't mean it doesn't get dirty.
