Poison Spyder JK Body Armor
Good Write-Up! That's basically what I did for mine too!
(Just without the rivnut tool, and I ended up throwing some reflective red tape under the Spyder cutout)
[/QUOTE]
Is this the final outcome? It looks as though you didn't install the bottom row bolts. If so how come? Does look good though I like the red spider and the bedlined pinch seem. How far up the pinch seem and rocker did you go or is it just pinch seem?
I just finished mine about two weeks ago, I used two coats of textured paint, looks good but as the screws went in it scratced the paint and now each is rusting this is big time salt country here too, I am going to pull it all off in the spring sand it and use the bedliner, looks very nice. going with color behind the cut as well, looks really great guys.
Thanks!
Yeah, that is the final outcome. Unfortunately, with my LoD sliders welded in place, I couldn't get a drill to the lower holes to get those nutserts & bolts in place. I may still be able to get the two outer ones on the ends, but I still need a longer drill bit to do those (since I'll need to go through the holes in the sliders that line up with the armor).
Other than that, they've been great. I didn't spray under the armor itself, just used the optional rubber liner and the red reflective tape, then covered the armor and spray bedlined any white spots showing when I was finished.
I used the installer from Rivet Nut Tool Dot Com with my air ratchet when I installed my Brawler Rockers. Worth every penny. Drill the hole, hit the tool with the air ratchet and you're done. Just be sure to go easy with the ratchet. The tool will crush the rivnut if you get carried away. Just a quick burst to snug it up. As cheap as they are, Poison Spyder should include one with every set of body armor that they sell.
