Power hard top hoist for @ $150.00 !
#21
All last summer my top was hanging from my garage ceiling with 4 motorcycle straps. Attached to 4 eyelets in the trusses, and hooked under the bottom of each side of the top. 2 on each side. No worries at all. Parked my hood under it all summer. If someone was too shove on it and shake it around, well then yes I suppose it COULD fall.
#22
To get mine closer to the ceiling, I mounted the hoist bar on 2 joists and dropped the line through a hole in the ceiling. It gives you a few more inches, which I needed with my low ceiling and a lift.
#23
Thanks
#24
You could leave it there as long as you want. All last summer my top was hanging from my garage ceiling with 4 motorcycle straps. Attached to 4 eyelets in the trusses, and hooked under the bottom of each side of the top. 2 on each side. No worries at all. Parked my hood under it all summer. If someone was too shove on it and shake it around, well then yes I suppose it COULD fall.
