Pro Comp Light Bar Instal directions w/Pics
The kit.
1. Lower the Air Dam by removing the four plastic screws and rivets. You will unscrew the screw all the way then pull out the rivet. The reason you will need to remove the air dam is to get to the inside of the bumper for bolting on the ligth bar later.
2. Line up the light bar 1 1/4 inches from the rear of the bumper lip. Then with a pencil mark the hole inside each end of the light bar. I made a pencil line at the 1 1/4 mark to ensure it was perfectly straight.
3. Center punch the mark.
4. Drill a 7/16 hole. Going through the plastic is like butter and is 3/4 deep till you hit the steel of the bumper support. Then drill a 3/4 hole only through the plastic bumper.
5. Insert the 3/4 inch washers.
6. Line up the light bar. Drop the bolts through the hole and rach under the bumper and attach and tighten the nuts.
7. Hammer in caps at each end of bar.
FINISHED! Now install the lights....
