Re-gear DIY?
Re-gear DIY?
I am NOT a pro mechanic but I am pretty confident when it comes to that stuff. Has anyone here ever tried this? I understand the basic procedure but I'd like to hear if any shadetree mechanics have attempted it. I just thought with the right tools, it could be done.
Yep I did mine and I had no prior experience. 20k miles and still doing fantastic. This thread was what I used for my DIY as well as some other resources. But this will get you started.
https://www.jk-forum.com/forums/jk-w...gearing-82262/
Wow,I have never seen such a detailed write up! This gives me alot of confidence. Thanks!
I have never done my own gears, and not sure I would on my DD.
My current housing was geared to 4.88 before I got it. When I replaced the axle seals, I could not get the carrier back in to the housing. Whoever did the gears had put so much preload on the bearings, that I had to ask someone else to help. They ended up using a case spreader to stretch the diff housing just enough to get it back in.
If my Jeep was a trailer princess, I might consider doing a job like this myself. Although it seems simple enough to follow a write up, when things don't quite go to plan, it's not always that black and white. Plus, the tolerances being so tight, that a small mistake could end up with disastrous results.
This, but no means, is meant to discourage you from giving it a go. Like I said, if I didn't need to drive it every day to work, I'd consider it. I'd be able to spend all the time I wanted to make sure it was right. But the $1000 or so in labor is worth it to me to be reasonably sure I'll have a vehicle to drive when I need it.
I have never done my own gears, and not sure I would on my DD. My current housing was geared to 4.88 before I got it. When I replaced the axle seals, I could not get the carrier back in to the housing. Whoever did the gears had put so much preload on the bearings, that I had to ask someone else to help. They ended up using a case spreader to stretch the diff housing just enough to get it back in. If my Jeep was a trailer princess, I might consider doing a job like this myself. Although it seems simple enough to follow a write up, when things don't quite go to plan, it's not always that black and white. Plus, the tolerances being so tight, that a small mistake could end up with disastrous results. This, but no means, is meant to discourage you from giving it a go. Like I said, if I didn't need to drive it every day to work, I'd consider it. I'd be able to spend all the time I wanted to make sure it was right. But the $1000 or so in labor is worth it to me to be reasonably sure I'll have a vehicle to drive when I need it.
I've known way too many people who blew their gears apart on the trail and you have to stop and wonder if it was just a bad day on the trail or if it was sloppy gear setup. Almost all the gears I have seen from local shops had horrible contact patterns. At least doing it myself, I only have myself to blame if something goes wrong.
Another sticking point for me was that I wanted to buy American made gears. And yes, I was able to find them from US Gear in 4.88 for my Rubicon. I couldn't find anyone willing to do the work with me bringing them the gears. They wouldn't warranty it or simply refused to do the setup entirely. So, again, that is why I did my own.
Well using the 3.6/auto chart you see everywhere giving the RPMs for tire size vs gear ratio, 4.11 seemed to be the best way to go. I currently run 33” which has me at about 2K at 70 mph. 4.11 would put me just slightly above that. However, I did consider 4.56 because I eventually want to go to 35” or 37” but I was afraid it was overkill. What do you think?
Well using the 3.6/auto chart you see everywhere giving the RPMs for tire size vs gear ratio, 4.11 seemed to be the best way to go. I currently run 33 which has me at about 2K at 70 mph. 4.11 would put me just slightly above that. However, I did consider 4.56 because I eventually want to go to 35 or 37 but I was afraid it was overkill. What do you think?
