Rear Pinch Seam / Rubicon Rail End Cap Trim
First I cut my slider and put the end cap back on and made a line on the pinch seam where I wanted to make the bend:
I first made the bend with my adjustable wrench:
I then got out the BFH and used it until it was level with the slider:
Painted:
Finished:
Painted:
Finished:
I used a sawzall to cut both the rock rail (after removing it) and the pinch seam. I really didn't want to go past the spot welds so I only took off about 1/4".
Cut rock rail and pinch seam:
Stuffed to the max before cutting:
Stuffed even more after cutting:
There's not much room but it doesn't touch. The tire was about as stuffed as it can get. We'll see what happens on the trail with lower tire pressures.
