Rear storage tub enlargement
JeepSWAG
Sponsoring Manufacturer
It's not completely finished, but good enough to show.
This one is fairly self explanatory. We made a Steel tub and coated it with LineX.
The opening is about 26" X 13", and it's about 6.5" deep. The tub sides at the front and both sides had to taper in, in order to allow room for the upper shock mounts. The back side is bolted to the "front side" of the jack storage tub (if that makes any sense). Pics will tell a much better story, than I.
I'd like to personally thank RockRash for his help on this. He did all the metal work, and hooked me up with the LineX. I'm stoked that I can store some more stuff.
Notes added 6/30/07:
We used 16 Gauge Steel. Had it coated with Linex prior to install, and used Herculiner to touch up after installation.
Used 3/16" SS bolts with lock nuts, on the sides. On the front lip, it is very difficult to get the nut on the bolt. I ended up using 3/16" SS rivots. I would recommend using rivots on the front lip, if not all the way around.
Here are a couple of diagrams. These are not to scale, and I would highly recommend measuring everything for your self. Please do not rely soley on my numbers.
I can think of some changes that could be made to make more space, but this is what worked for me. For instance, you could do the sides of the tub at 90 degrees to the bottom, and have a greater angle on the front to work around the upper shock mounts. I'd encourage you to get under your jeep and lets see what ya got.
Ditto! This is an excellent mod I've been thinking about but needed to see someone on this forum try it first. Did you have to make a new top cover or will the stock one fit? Now that you've built this, are you happy with the dimensions or could it be made larger. I want to store all my tools and recovery gear out of site and locked if possible and need all the storage space I can get in my 2 door.
Great job and thanks. More pictures please
JeepSWAG
Nope. I live in SoCal. The only water in this tub will be from beer over ice.
