Reds fender trim with detailed pics and video!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old 04-18-2014, 10:24 PM
  #721
Philip *AZ*'s Avatar
I will post some pics of a Red Rock JK. They are not mine. The owner is on JK-F though.
Old 04-23-2014, 12:25 AM
  #722
jeremyreed's Avatar
Hmmmmmm
Sent from my SM-N900V using Tapatalk
Old 06-16-2014, 12:53 PM
  #723
BWN?'s Avatar
Just did mine this weekend. Took me the better part of the day, but I took my time trimming because I didn't want to use the door trim around the edges. I also pulled all the fenders off and sprayed them with bedliner as well as each wheel well. I am pretty happy with how it came out.
Old 06-18-2014, 04:48 PM
  #724
RJEEPO's Avatar
Thumbs up
Originally Posted by inspect-a-home
Here you go. Just used the jig saw and some tape, then used door trim to finish it off.
It's beautiful!
Over here we have safety inspection (they even take a pic of your ride for the record) and even a second level inspection called recon. Problems for me I think the flare needs to cover the tire, for sure they'd want a mud flap and then a DOT approved side marker. But man would it be sweet to run this style fenders! Great job, love the shaping!
edit: I seen the removable mud flaps "on a stick". wonder if I can get those to pass then can remove off road.
Old 09-11-2014, 05:35 PM
  #725
bigALh79's Avatar
This is on my list of mods to try out.
Old 09-12-2014, 09:27 AM
  #726
Vladimer's Avatar
Great write up, Red!
I've added it to the https://www.jk-forum.com/forums/modi...ontier-309589/ thread.
Old 09-14-2014, 05:01 PM
  #727
DeAnda's Avatar
Finally got around to it! Painted them while I was at it. Plan to get after the rear ones ASAPA!
ID:	575667   Click image for larger version
ID:	575668   Click image for larger version
ID:	575669   Click image for larger version
Old 09-21-2014, 11:40 PM
  #728
ATFPat's Avatar
I went through a few pages and have to ask. I found a used set of fender flares off from a 4 door 2014 wrangler. Question is is there any difference between an unlimited fender flares vs a two door wrangler fender flares in regards to fitment? Like will four door flares work on two doors? Not sure if there is a difference.
Old 09-22-2014, 12:56 AM
  #729
AngryRedBird's Avatar
I believe there is a minute difference with the rear flares.. but only slight. Think they can be retro fitted on the jeep.. (from a JKU to a JK) with a slight bow or rounded look in the middle..
Old 09-22-2014, 07:42 PM
  #730
ATFPat's Avatar
^ Cool thanks! have to pick them up and cut em up! Found a cheap pair on Craigslist.
Quick Reply: Reds fender trim with detailed pics and video!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
