Rock Hard license plate relocation bracket + ORO LED PlateLite install on XRC bumper
#81
Check post number 32 in this thread. This is the wiring method I used. You have to snip a wire from the harness that goes to your existing stock tailgate light which is for the rock hard brake light. The other 2 wires on your jk ( black and white w/ purple) will be going directly to the tailgate lamp so you will have to undo the screws on the rear passenger tail lamp to make all of these splices. Lemme know if you need any more help.
Biggest problem I ran into was the removal of the stock license plate frame since the bottom two bolts were sandwiches my aftermarket bumper. Rather than making the install go that much longer I just ripped it off. I'll post photos in a few.
#82
Thinking about doing this mod myself, but thought I would pass on some info. If you want to know which wire to tap into, open your tailgate and pop off the two blck plastic covers. You can trace the wires that exit through the rear door for the third brake light (only two wires total for ground and power) and follow these all the way back to where you tap them in the tub. Just did this for the lite dot mod for the rear third brake light, but thinking of converting to the spare mounted license plate instead.
#83
I have the parts to do this but did it come with bolts to attach the license plate to the bracket? Or did you just go get some. I'm thinking about just grabbing some quarter 20 hardware
#84
#86
#88
New guy here...matter of fact, I found this place while googling ORO PlateLite install.
I have a 2015 JKU Sport.
So the kit shows up on my doorstep Saturday from QT. I install it. First issue, I had the blinking brake light.
Today (Monday) I dig deeper in the thread and find how to tap into the tailgate and the third brake light. I do that (splicing the brown/white to red) and now no more blinking brake light.
I basically pulled the red white from the harness and directed it down the tailgate to the factory harness for the 3rd brake light. I spliced there, then left everything else connected to the passenger side tail light. (ground, and green wire for white LED)
Tonight, I go out and eat. I get back home and double check everything. Here's the latest issue I have.
When the brake light is on the plate light and the factory 3rd brake light, my white LEDs go out on my license plate. When my brake isn't pressed, the white LEDs on the license plate are lit.
When the harness is tapped into the factory wiring like what's in the original post, everything works except the brake light blinks when the right turn signal is on or the hazards are on.
I'm debating just removing the splicer from the red in the hardness and the brown white in the tailgate so the white LED will stay on while the brake is pressed. I just like having the LED brake light there since my 35" spare covers the factory third brake light. If there's someone right behind me with their lights on, it isn't going to matter and shouldn't be noticeable.
#90
I thought the trick was to tap into the wiring harness on the side of the plug that's furthest from the brake light. I haven't dug into mine yet, but I believe that's the female end.
