Rugged Ridge 4-Door JK Bowless Top Install
Old 09-28-2015, 06:34 AM
  #21
sm_rubi's Avatar
Originally Posted by Dieselj
Thanks for the write up. I've been looking at this type of top for a while.
Does the rear window come out or is it permanent?
It's sewn at the top which I wasn't sure about but I really like it because it rolls up and has straps to keep it up and out of the way. So quickly you can go from full top to bikini top.
Old 09-28-2015, 06:35 AM
  #22
DesertJeep's Avatar
Nice job, sm_rubi and Blonda! I found that the instructions in the box were pretty good, but there are definitely some good tips here that will make the install goes just that much more smoothly. Making sure the top is warm before trying to put it on and figuring out the correct orientation of the header bar clamps will save you grief. And knowing that that the ends of the bows need to go INTO the pockets and not just over them will definitely extend the life of your top.
Old 09-28-2015, 01:10 PM
  #23
sm_rubi's Avatar
Thanks Bill! And thanks for lending a hand!
Old 09-28-2015, 05:41 PM
  #24
harve22's Avatar
Frank/Brenda, great job on the write up. If I understood it correctly the pre-2010 door surrounds do not need any modification to them. The top should clip right in correct?
Old 09-29-2015, 09:14 PM
  #25
JCDriller's Avatar
Can the front of this be flipped back and secured like the sun rider top?
Old 09-30-2015, 05:17 PM
  #26
sm_rubi's Avatar
You got it right Tony the pre-2010 surrounds is the way to go to reduce the install time quite a bit!
I don't think it's possible to do that configuration but I'll discuss it with them as feedback. There is a couple of support poles that would prevent that, but, it may be possible without the poles?.
Old 09-30-2015, 07:22 PM
  #27
69mach1's Avatar
Cool
Great write up Brenda Nice to see you had a willing helper
Old 10-01-2015, 06:29 AM
  #28
sm_rubi's Avatar
Thanks Jon I follow instructions pretty er....never mind. Thanks she did a really nice job documenting the install and hopefully some of our feedback with be applied to make the instructions a bit easier for the next person.
Old 09-27-2016, 08:17 AM
  #29
Davis3613's Avatar
Default Update
How has this top held up? I have one on order now.
Old 09-27-2016, 08:56 AM
  #30
DesertJeep's Avatar
Mine's been on my Jeep since February or March, and it's held up great. No stretching or tearing. The windows seem like they're a lot less prone to scratching than the oem soft top windows.
Quick Reply: Rugged Ridge 4-Door JK Bowless Top Install
