SPAL Fan install
Dude, that is SUCH a better installation than my super ghetto hack job... I did mine on a wing and a prayer since I had to leave the next morning to drive to Charleston for my wedding... So I just needed something to make it that far. Seems to be holding up well though. Nice job, and I would definitely have followed your write up over mine...
For everyone worried about the two speed deal, I'm not worried about it too much. When the new fan kicks on, it cools things down in a hurry...
I wouldnt think its any more susceptable to burning out than a stock fan. I mean, they should be meant to last the life of the vehicle technically, so I'd assume its going to last. If not, I'm gonna be bitchin up a storm to SPAL to get my money back...
Location: Hangin in the sunshine state....staging forum..
I agree I dont think it turning on and off with hurt at all, they are all designed to do that. I sent an email to spal asking if he knows why it wouldnt be working on low speed and about the shuting on and off. He said wiring it up with the diagram he gave might make it work on low and high I'm not sure about that because the stock fan using the same wires runs on high and low, but I know there are 2 different relays for the high and low, so I dont think its really the motor itself that has 2 different speeds, its more of what power its getting from the computer. I know spal makes a controller that has 2 different speeds, so thats why I believe its the power its receiving that makes the difference, I believe he told me in the beginning we couldnt use those controllers though.
How does the jeep seem to be running temp wise with the fan? Are they louder? Mine should be here friday on monday I think. It will be interesting because I have the aeroforce gauge and can see the temp in digital reading. I've seen my fan on low but I'm not sure when it and how long it stays on low, I've checked it 205 and not had it on. I know at 215 it comes in high all the time
My temp never goes over half way. I'm not worried about the fan cooling because it kicks butt. I was going to wire it up IAW the diagram but my buddy said "Why reinvent the wheel". The Jeep already seperates the high and low voltages and sends it down the two wires to the fan. I tell you it's that darn mysterious green resistor. The three wires go to the top of the radiator to that connection are high, low, and ground. Then some how they merge and become two wires (hot wire and ground wire) to the fan. Somehow they go through that resistor thingy. All in all I am happy with the install and I am looking forward to seeing tkob060's write-up.
Just wondering if anyone has figured this thing out yet with the one speed. I just talked to someone from spal and they said that the fan is a one speed motor. There is a temperature switch that you can buy from them and it will automatically turn the motor on when it hits 185
I just purchased the fan cause mine failed and it keeps popping fuses anytime i try to turn the ac on.
check this out guys maybe this will help out with both low and high fan speeds and temps..
http://www.spalusa.com/store/main.as...tem=FAN-PWM-V3
You simply choose the Low and High temperature settings you desire. When the low temperature setting is reached the fan begins spinning at 50% speed. As the engine temperature increases, the speed of the fan slowly increases until it reaches the High setting, where it is then running at 100%.
Great something else to buy......Well if you put a switch to this fan couldnt you just switch it on whenever your temp gauge is goign up....example....when tkrob is doing 70 to 75 on the interstate.
#2 the fan is on when I am on the highway since putting the spal on because my temp is always over 215 which makes the fan run on high
