Transmission Cooler
Old 05-14-2014, 08:23 PM
  #691
fitzb's Avatar
Installed mine today. PSC dual cooler. Pretty easy install.
Old 06-20-2015, 01:32 PM
  #692
JeepinCO's Avatar
Thanks for this write up. It was super easy to do, especially considering I'm pretty much a "Tim the Tool Man" with vehicles.
Old 08-02-2015, 06:11 PM
  #693
JeepinCO's Avatar
I tried this write up this weekend using the parts specified and I can't seem to get the point where the hoses connect to stop leaking. I've tried wrenching down the clamps as tight as i can, but it still seeps out. Any ideas?
Old 08-04-2015, 09:25 AM
  #694
fultonromero12's Avatar
Did you use the barbs fittings that came with the cooler or buy some different. Just asking bc I tried using the ones in the B&M pack and they leaked for some reason. I purchased some at Home Depot and no leaks. Post pics so we can see your setup and maybe spot the problem.
Old 08-06-2015, 08:00 AM
  #695
JeepinCO's Avatar
I used barbs from Home Depot and for some reason can't get it to stop leaking. I'm taking it to a 4WD shop next week to see if they can fix it
Old 08-06-2015, 10:15 AM
  #696
Maertz's Avatar
Did you Loctite 567/565 them barbs?
Old 08-07-2015, 06:18 AM
  #697
JeepinCO's Avatar
I don't recall seeing that on the list of parts to use. Has anyone else use it and have good results?
Old 02-12-2017, 04:27 PM
  #698
JK Pilot's Avatar
Originally Posted by schmugboy
Anyone have an idea or opinion on whether this would void the lifetime powertriain warranty?
This question is like a virus that won't die. Factory warranties are not automatically void with aftermarket parts. The factory or warranty company must prove that the aftermarket part caused the failure. This was litigated years ago and the automakers lost.
Old 02-12-2017, 04:54 PM
  #699
JK Pilot's Avatar
Originally Posted by adamisadam
If the tranny temps are down overall, say by 20* for example, then as that fluid enters the radiator it's 20* cooler so less heat in there in general - which means the anti-freeze gets more of the radiator's efforts.
That's an interesting thought. makes sense.
My 09 Rubicon trans fluid cooler is on the A/C condenser. Doesn't run through the radiator. know that because for most warranties, the trans re manufacturers require proof of radiator replacements. I ordered a new rad before I knew this and was plenty upset with myself for nor looking first.
Old 02-12-2017, 05:07 PM
  #700
JK Pilot's Avatar
Originally Posted by Slightlymodified
I realy want to do this mod, but my dealership said it would void my warranty if i added a cooler.
Either find another dealer or an employee there with a brain.
More entertaining, ask him for written proof of his assertion, then sit back and watch the fun.
Quick Reply: Transmission Cooler
