Wheel Stud Replacement.
#21
#22
One thing that should have been mentioned but wasn't.
NEVER EVER hang the brake caliper by the brake line. Use a piece of wire to tie it up out of the way. Hanging it by the brake line can cause the line to fail.
Other than that, great write up.
#23
Any thoughts on how to replace a lug out of a spidertrax spacer? My fine and dandy tire shop cross threaded one on my spacer. It was just spinning in the spacer so I couldnt get the lug nut off. I had to drill it out. Not such a big deal now as I just got some 35s and new wheels with less backspacing. But I scuffed my rubi takeoffs on the inside of the rim and my new tie rod too. dammmmiiiiit. If I want to use those again I will have to put the spacers back on.
#26
I've had 6 of mine broken: different shops, different times. 2 of them at the dealer. Anyway, I claimed to the service manager that there is something wrong with the strength/durability of the studs..they are too week. He didn't buy it, said I would still have to pay for the replacement PLUS labor. Said that it was the previous person that put the wheels back on that overtorqued. He also added "besides, I could claim your oversized /aftermarket tires put additional stress on the lugs.
Point is thanks for the writeup so now I can replace myself if I ever break them after working under the jeep for some reason. Will probably still pay for rotation as I like to have them balanced each time. And since I had the tires rotated and lug done at the dealership, I'll take back to them, in the event a lug breaks and they claim overtorque, I have record that it was their techs that did it last
#27
Just wanted to say thanks for this thread.
Stealership wanted $50 for parts and labor. I did it for a about $15 and half hour of time.
Was interesting to find that the stud was not available at any local auto parts store for a 2010 (every one (napa, advance, pep boys, etc. said you could special order or go to dealer only). Bought the stud for $13 from the dealer and $2 for some washers at Lowes.
Interestingly enough, the only people that have ever touched my tires/studs has been the dealership since I have lifetime tire rotations/oil changes with them and I am still stock. So they couldn't use that bullshit excuse listed in the post above on me. Pisses me off to think one of shop guys got super happy with a torque wrench and Fd it up in the first place.
Oh well, just love this forum...
#29
Noob here. Thanks for the great information. I just replaced all five studs on my JKU. I don't know if the dealer left the lug nuts loose and got damaged by driving with loose lugs or if someone tried to jack my rims. The studs are $2 each at O'Reilly. The hardest part was that I had to stand on the lug wrench to crank the studs in place. I put so much pressure on the factory lug wrench that the paint was chipping off near the bent part by the "socket".
#30
A good breaker bar makes short work of the stud install. I used a 1/2 bar to destroy the old stud after my impact gun couldn't get the nut off and a 3/8 bar to install the new stud.
x2 on not re-using the nut.
Be careful at O'Riely's some of them are easily confused, the part number is 610-448. I got 610-449 the first time and it just spun in the hub. Both say "Jeep OEM" on the box.
