Write- Up Diagnosing Death Wobble and Fixing Non-DW Shimmies and Wobbles
Old 07-04-2013, 05:08 PM
  #121
Forum Tech Advisor
planman's Avatar
Originally Posted by DamonK
I have read your very well written diagnosis on the wobble problems. I have had this for nearly two years chasing the problem with no success. A buddy came over and reproduced the feel of the wobble by moving the transfer case with his foot. He feels that the mount is bad which allows the wobble. I tend to agree because of the look and feel of the vehicle when he jostled it. Is there supposed to be 2-3 inches of movement in the transfer case?
No. The transfer case should not move 2-3". You have a broken mount, loose bolts, or worn a worn bushing.
Old 07-05-2013, 09:02 PM
  #122
DamonK's Avatar
Default Is this a cause of dw
Hello, thanks for the reply. So I have done about 80 percent of what you suggested. I really appreciate your time and expertise. So, could fixing the mount or worn bushing stop the dw?
Old 07-05-2013, 09:53 PM
  #123
Forum Tech Advisor
planman's Avatar
I wouldn't classify vibrations from broke or worn engine/tranny/transfer case mounts as death wobble.
It sounds like you have multiple things going on.
Old 07-06-2013, 07:15 AM
  #124
catahoula's Avatar
I had some clunking and it was due to loose swaybar links.
Sent while sitting in my Jeep using JK-Forum
Old 07-06-2013, 07:47 AM
  #125
AaronJK's Avatar
First I found the drag link was shot at the steering knuckle, replaced that and the shimmy decreased, but didn't go away. I pulled into work with the shimmy present and had someone help me check and found tons of play in the tie rod that hadn't shown up before. Also found my drivers side lower ball joint is going and the passenger side is gone. You can feel the clunk when you lift the tire easily. Fixed the tie rod, now just waiting for a day to replace the ball joints. Thanks for this write up planman, I feel like an expert now lol.
Sent using my SuperSmartThinky Phone
Old 07-06-2013, 04:14 PM
  #126
Forum Tech Advisor
planman's Avatar
Thank you. I really appreciate it.
I like to see people fix their problems instead of letting an untrained dealer service department mask them with new steering stabilizers.
Old 08-29-2013, 05:43 PM
  #127
GCiron01's Avatar
Default 99 TJ with death wobble
I see that you mention JK jeeps, but what about TJ.
I have a bad case of death wobble. I intend to go through the checklist, but wanted to ask if there was anything else regarding the TJ.
Not knowing anything, I replaced the track bar and the larger bolts.
I'm gonna do the checklist tomorrow.
I watched a bunch of your videos
Thx
Old 08-29-2013, 06:04 PM
  #128
Forum Tech Advisor
planman's Avatar
Thx
The design principles are the same.
The torque specs and bolt sizes are different.
Old 08-30-2013, 08:29 AM
  #129
GCiron01's Avatar
After inspection, track bar passenger side was loose. Also the Pittman arm has considerable play. I relighted track bar and I guess I'm going to try and fine a new bushing for the Pittman.
Old 08-30-2013, 10:52 AM
  #130
Forum Tech Advisor
planman's Avatar
If the pitman arm has play at the box, the steering box sector shaft may be damaged.
If the drag link end at the pitman arm is bad, then that can be replaced.
Quick Reply: Write- Up Diagnosing Death Wobble and Fixing Non-DW Shimmies and Wobbles
