Write- Up Diagnosing Death Wobble and Fixing Non-DW Shimmies and Wobbles
#251
Forum Tech Advisor
I like Synergy, JKS, and Teraflex front trackbars, but I'd be open to using Rock Krawler, EVO, and other quality companies as well.
#253
Ok. I know yal are sick of hearing from me on this.. I finally did a through test as plan man did in his video.. I have a hard bump coming from my drag link. I can get my channel locks and get a little up and down movement on my tie rod ends, but no bumps when turning the wheel. I see a little deflection in the bushings on my track bar unit bearings are good and ball joints are good. What do yal reccomend? Draglink flip? Or just replace the draglink? The problem arises that I have no idea what brand lift I have nor do I know exactly how much lift I have.. I also don't know if the lift that was installed used a drop pitman arm or if it's still stock.. I know it's ignorant but I bought the jeep already lifted. Also should I go ahead and replace the tierod since I have a little up and down movement? Thanks for any help.I'm looking at the synergy high steer drag link kit and using the synergy draglink flip adapter do yal think that this will work with my set up or do I need to go another direction? I know I haven't provided much information but if you have any questions just ask.
#254
Forum Tech Advisor
Just replace the parts that are worn.
You may need to perform the written checklist at the beginning of this thread. It is more thorough than what I show in the videos.
#255
planman - I have a question for you since I got no replies on JKO.
I am putting on artec track bar brackets front and rear, the front is the raised mount for a drag link flip - already have both brackets. I am doing this mainly because i want to address "failure prone" areas, no matter how little. I have a synergy drag link, not installed yet.
I have a roughly 4" lift - mostly teraflex. 2.75" bumpstops up front with a teraflex adjustable track bar - any idea if that will work with a drag link flip? I've heard it could rub the sector shaft. any ideas?
the bumps are longer than I need since I only have 35s, but i have full fenders and shock extensions so they match my bumpstops currently.
any help would be appreciated, I really want to avoid getting a different track bar if possible.
#256
A drag link flip kit requires 3" or more front extended bumpstops. It doesn't make sense unless you are running at least a 4" lift or 37" tires with stock flares. Just replace the parts that are worn. You may need to perform the written checklist at the beginning of this thread. It is more thorough than what I show in the videos.
#257
Forum Tech Advisor
Forum Tech Advisor
planman - I have a question for you since I got no replies on JKO. I am putting on artec track bar brackets front and rear, the front is the raised mount for a drag link flip - already have both brackets. I am doing this mainly because i want to address "failure prone" areas, no matter how little. I have a synergy drag link, not installed yet. I have a roughly 4" lift - mostly teraflex. 2.75" bumpstops up front with a teraflex adjustable track bar - any idea if that will work with a drag link flip? I've heard it could rub the sector shaft. any ideas? the bumps are longer than I need since I only have 35s, but i have full fenders and shock extensions so they match my bumpstops currently. any help would be appreciated, I really want to avoid getting a different track bar if possible.
You can use the Synergy drag link. However, you will need to ream the knuckle and install an insert.
You shouldn't have any sector shaft problems.
#259
Hey guys. Just upgrading to a prorock 44 unlimited at the moment. It did not come with a trackbar raised bracket... Do I need one?
I'm running the rk 3.5 max travel so it had a trackbar bracket and my draglink is flipped... I have a feeling I'll need one but your input of anyone running somewhat close to my setup would be greatly appreciated
#260
Forum Tech Advisor
