Sponsored by:
Sponsored by:
14 bolt and HP dana 60 in a JK
Old 08-06-2014, 07:07 PM
  #221
Philip *AZ*'s Avatar
Originally Posted by Maertz
vks fab makes some tone rings for the rear 14 bolt hubs wich i am running, there simple as can be. Not sure ho pricey the dynatrac kit is...Been a bit since ive been on there site but i believe they make d60 ones also?
Thank you Maertz. I will definitely pick up a set of those.
www.facebook.com/NewHorizonOffRoad
Old 08-07-2014, 05:03 AM
  #222
dr.dirty's Avatar
Originally Posted by Philip *AZ*
I found a complete 14 bolt disc conversion at East Coast Gear Supply. $300.
Kit includes:
Single rear wheel 3/8 bracket.
Mounting Hardware for caliper to bracket.
L/R 1/2 Ton calipers
New Pads
New 8 lug rotors
Two 12" long braided stainless lines.
24" and 48" long hard lines.
Mounting hardware for lines.
Hub seals
Long or short studs
Your paying for convenience in that package. If your thrifty and shop around you can find what you need for the rear brakes fairly cheap. I think my rear calipers and pads were less than 50 bucks at the local parts house. rotors were like 35 each and the brackets were like 45 bucks. The VKS tone rings are the best price on the market and work great.
Old 08-07-2014, 06:09 AM
  #223
Maertz's Avatar
Agreed here i think my disc brake conversion was no more than 200 and all stocked locally other than the brackets.
Old 08-07-2014, 07:02 AM
  #224
Ok. Thanks guys
Old 08-30-2014, 03:30 PM
  #225
dr.dirty's Avatar
Finally am happy with the coil over tower covers. Had the tub line xed pretty happy with the results. Click image for larger version
ID:	573624Click image for larger version
ID:	573625Click image for larger version
Also did the corners as well.
Old 08-30-2014, 08:20 PM
  #226
sm_rubi's Avatar
Finally am happy with the coil over tower covers. Had the tub line xed pretty happy with the results. Attachment 573624Attachment 573625Attachment 573626
Attachment 573627
Looks awesome! Like the finished look of the shock tower covers!
Old 10-01-2014, 09:15 AM
  #227
dr.dirty's Avatar
Got the Reids and Artec Arms installed with the knuckle tie in kit.
Old 12-29-2014, 03:48 PM
  #228
notajerryskid's Avatar
When you used the JK8 brake master cylinder, Did you have to trim the plunger or do any modifications?
Quick Reply: 14 bolt and HP dana 60 in a JK
