2.5" RK lift and 35" Tires
Hey everyone, I'm new here and recently started building my jeep (2011 JKU Sport 6-speed 3.73) for this coming spring. I plan mostly on running off road trails in N GA and camping out.
Here is a list of mods that I have currently done or am in the process of doing:
-Front bumper: Maximum Jeep Trailblazer HD2
-Winch: Smittybilt XRC 9500 w/ steel cable
-20" Light bar
-LED head and tail lights
-Rear bumper: Maximum Jeep rear bumper w/ tire carrier (in progress, issue mounting. Rear ended back in July, rear crossmember may have been welded back too far back)
-Rugged Ridge Exo top (in progess, waiting for a sunny, warm weekend to install)
Regarding a lift and tires here is what I have planned:
-Northridge RK 2.5" lift. Debating whether to get the Flex or Max travel package. I don't really plan on further suspension modification, so I'm not sure whether the rear LCAs and Brake lines are worth it.
-35"x12.5"x15 Cooper Discoverer STT mounted on 15x8 MB Razor Wheels (Probably going to pull the trigger on these soon. DTD President's Day sale ends Mon.)
After that I'm planing on CA skids, Evap Skid, and an Oil Pan Skid. Then reinforcing the front axle, changing gears, and probably adding a rear locker.
My biggest questions are regarding the Flex vs Max Travel, and whether those tires will mount and balance on those wheels. But also which order I should do the skids and driveline modifications.
Thanks in advance!
-20" Light bar
Thanks in advance!
Former Vendor
-20" Light bar
Thanks in advance!
-20" Light bar
Thanks in advance!
We typically recommend going flex initially. If you plan on doing flat fender in the future, we recommend upgrading then to the rear lower and upper arms. That will push the rear axle back and re-center the axle in the, new larger, wheel well opening.
You may have clearance issues on those wheels. 15" wheels, depending on MFG, have clearance issues often with the caliper.
I've seen a few threads from the MFG and others stating that these wheels clear the calipers, I think the fact that they're alloy vs steel helps with clearance issues.
Attachment 637188
Pretty much my same setup with the addition of adjustable arms, 17's and 2 less doors! Be sure to post up some pictures when you get everything dialed in.
I just put on a 2.5 x-factor on my 2 door last weekend. 100 yds out of the shop and I wanted new brakes, just ordered them today actually. I would seriously consider 17s, it will be much easier to find brake upgrades. I believe the cost of replacing pads and rotors would eat up the cost of cheaper tires otherwise.
