Sponsored by:
Sponsored by:
After 2.5" lift my rear brake line touching shock.
Old 10-16-2012, 11:58 AM
keahyukchang's Avatar
Default After 2.5" lift my rear brake line touching shock.
Is this okay? Can't remember if this brake oil line was touching before the mod.
- Will post picture soon.
Old 10-17-2012, 03:56 PM
Default Photo : Brake line rubbing shock...
It seems I should do something about the brake line.
ID:	379388Click image for larger version
Old 10-17-2012, 03:58 PM
Bxjk's Avatar
I had the same issue. Bend the brake line gently away from the shock and you should be good. I caught mine as it was wearing into the brake line.
Old 10-17-2012, 04:50 PM
gunbo75's Avatar
X2 on that. Just keep an eye on it after you wheel too .
Old 10-17-2012, 05:37 PM
Vin
Vin's Avatar
x3 I noticed it would hit on bumps. I spend days tightening and retightening bolts. I was ready to just live with it until I was underneath with some black spray paint to hit my muffler and rear axle when I noticed the mark on my shock. I gave it a little nudge and wasn't even sure if I did anything, but no more noise when I hit bumps.
Old 10-23-2012, 11:59 AM
Default So far, no rubbing
Followed the recommendations using gentle bending with hand for rear (driver side to move more front, passenger side to move rear) and front lines just readjust the angle in the bracket.
So far, no rubbing.
thanks for all help...
Quick Reply: After 2.5" lift my rear brake line touching shock.
