Sponsored by:
Sponsored by:
2015 Lift question
Old 03-10-2015, 03:00 AM
jkd3624's Avatar
Default 2015 Lift question
Just bought a 2015 unlimited first time I have owned a 4 door and then I have rumors about needing something to do with the exhaust for a lift for flex and what not. So here is my question.
On a 2015 unlimited how much lift can I put in before I have to worry about changing out the drive shafts? Second question what needs to be Done to the exhaust when lifting a new jeep??
I'm not looking at a crazy height for a lift only 2.5" to start. So I can do mild trails nothing overly crazy.
Old 03-10-2015, 03:06 AM
Grubbicon's Avatar
With only a 2.5 lift you should be fine on driveshafts for awhile and sorry but i cant help with your exhaust question.
Old 03-10-2015, 03:13 AM
jkd3624's Avatar
Can I sneak up to a 3.5" lift on light trails with stick drive shafts??
Old 03-10-2015, 03:33 AM
MDRoots's Avatar
Subbed for information I've been trying to ignore about my 3.5" lift
Old 03-10-2015, 04:21 AM
GJeep's Avatar
On a JKU, with 3.5"~4" lift I'd replace the front drive shaft. (On a 2-dr, the rear DS angle becomes problematic and should be replaced.)
On my JKU, I replaced the front DS with JE Reel 1350 (many think that a 1310 would be enough). After about 2 yrs of DD and offroading, there's no problem with the rear DS.
Old 03-10-2015, 04:55 AM
TheDirtman's Avatar
Why do you want 3.5" of lift?
Old 03-10-2015, 05:04 AM
jkd3624's Avatar
It's the end height I want I like that look with 37's and flat fares I don't want to buy springs twice and it looks good with 33's and stock flares
Old 03-10-2015, 05:05 AM
jkd3624's Avatar
So really a personal preference ........
Old 03-10-2015, 05:54 AM
Grubbicon's Avatar
You can do it for awhile but its not going to be a permanent thing. My Jeep was like this when I got it but shortly after I ripped the boots on the driveshafts and just ran them till they had enough. So if you don't want to spend the money on it eventually I would suggest staying with the 2.5 idea.
Old 03-10-2015, 07:13 AM
Sponsoring Manufacturer
TeraFlex's Avatar
With 2012+ JK you can run a 2.5" kit without having to change the exhaust or driveshaft, at least with a TeraFlex kit. Now if you run a 2.5" with longer 3-4" shocks, then you will need to install exhaust spacers (#2610000 TeraFlex) and change the front driveshaft out. Unless you install front limiting straps then you will only need the exhaust spacers.
Quick Reply: 2015 Lift question
