3" lift dropped my mpg 4 miles
I've had a 2" lift on my 2012 since new and typically got 18-19 mpg on the highway. Recently added bumpers, tire carrier, winch and went from 32" to 34" tires and lost some performance and 2-3 mpg. I corrected my tire size with my Superchips Trail Dash 2.
Last week I set my programming back to stock to take it in for service. After service, I forgot how to change the tire size back, and programmed in the 87 octane tune and then tire size.
My performance is much crisper, strong as ever with the 87 octane tune. And I've picked up a couple of mpg's as well. The tuner helps.
Hello everyone, after three years of running ALL STOCK, finally having 3" lift with 35" BFG KM2 installed as I write. My question, is adusting your fuel and speedometer a DIY task? Or should I have a professional do this. Currently running 3.73's and planning to upgrade to 4.50's in a few weeks. Should I wait till then? Thank you all ahead of time.
You can do it yourself with a programmer. The least expensive Superchips Flashcal and AEV ProCal will do tire size and gear changes. If you want to do engine tuning to get better performance you need the more expensive Superchips Flashpaq or Trail Dash 2 units. There are threads on programmers and tuners. You can do the tire size first, and the gear change later.
I installed a 2.5" lift (lifted the front a lot more than that due to sagged springs) and it didn't really affect my fuel economy. Once I put on a set of 35" Trail Grapplers without regearing from 4:10, my economy tanked. I went from 10-13L/100km on the highway to 16-19L/100km. With a light bar installed I get better fuel economy during normal city driving at 60-80km/h.
The biggest detriment to fuel economy is wider tires. Lifting up does reduce your underbody aerodynamics a bit, but tire width not only wrecks your aerodynamic profile, but it also increases your rolling resistance and unsprung weight.
I'd agree that is not enough of a difference to worry about it, just realize it will throw off the odometer and computer calculated efficiency a little. You're still right though, mainly looking at larger tire and added wind resistance sitting higher. I get 13.5mpg if it makes you feel any better.
My 09 was getting 20 - 22 mpg hwy until the 1.5" lift, bumper, sliders and skids. Same 32" tires and same flashed 87 tune. All those beefy steel parts added about 400lbs of weight. Now I'm lucky if I hit 20mpg hwy even briefly.
