4wd linkage cable adjustable
I replaced my transmission and since putting it back in my jeep will not shift into 4lo and slides out of 4 hi into 2wd with ease. Is the cable adjustable?
Same transmission? Double check the shift cable and linkage for the transfer case. Replacing the trans shouldn't make a difference If it was the same one. I and many others swap t-cases without issue.
