Sponsored by:
Sponsored by:
Adams driveshafts
Old 12-05-2016, 03:28 PM
Chuck-The-Ripper's Avatar
Originally Posted by Invest2m4
The JK really doesn't create enough torque to break a 1310 driveshaft. I'd run those with 40s no problem unless you have a motor swap. I've seen everything break on a trail, but I have not seen someone blow a 1310 u-joint on a driveshaft (unless it was from being driven into a rock, which would take a 1350 out as well). Pretty sure Dirtman is running 1310s on 40s and he wheels the crap out of his rig.
Are you talking about snapping the cross section or caps? Because mine breaks the caps all the time, but only the 2 caps that are held in by the straps.
Old 12-05-2016, 05:33 PM
TheDirtman's Avatar
Yes, I run 1310 joints and had them built at a local shop.
Old 12-05-2016, 06:18 PM
Ryan0260's Avatar
Originally Posted by Ghostjku0910
What size tires are you running ? I was told 35-37 you can rock the 1310's is that accurate?
I'm running 37's. Like Invest said, 1310's should honestly be fine for most stock motor applications, and plenty run 1310's and 37's with no problems.
I like to buy things once, so went heavy duty with sealed joints, that way I am covered down the road if I decide to go bigger.
Old 12-06-2016, 11:47 AM
TxJeepers's Avatar
Front Adams 1310 here and no issues. Would buy from Adams again.
Old 12-06-2016, 03:03 PM
irishman001's Avatar
Are the Adams on part with Tom Woods?
Old 12-06-2016, 05:08 PM
TweakJK's Avatar
I can absolutely agree with this. I broke a 30 spline dana 60 axle stub with a 1310 tom woods shaft. People underestimate the 1310. The only reason I went with 1350 in the rear is because they dont make 1310 yokes for 14 bolts. That and 1310 on a rear axle turning sticky 40's may be pushing it.
The "you need a 1350 drive shaft for 37"+ tires" thing that you see on manufacturers websites is marketing. It costs very little to make a 1350 over a 1310.
Now, I must add, if you want to buy a driveshaft, call Adams directly. James Adams himself will probably answer the phone and he will know exactly what you need. I paid $444 shipped for a custom length 1350 shaft minus pinion yoke. The best part was that it was installed under my jeep 48 hours after calling him.
Old 12-06-2016, 05:42 PM
Punkineater's Avatar
Just ordered my 1350 sealed front and rear today. Have heard great things about Adams and looking forward to them.
Old 12-06-2016, 07:36 PM
lkjk's Avatar
how did you get this so cheap?
Old 12-06-2016, 07:37 PM
JP93XJ's Avatar
Great products and great service. Very knowledgeable people
Old 12-06-2016, 08:43 PM
TweakJK's Avatar
I just called them directly and that's the price they wanted. That was minus pinion yoke which is probably $80, I already had one. Still pretty cheap.
Northridge and quadratec really jack up the price. I paid more for my 1310 tom woods from quadratec.
Buddy got 1350 front and rear adams for right around $1000, but I think they were running a deal.
Quick Reply: Adams driveshafts
