adjustable front track bar really necessary?
Is an adjustable track bar really needed on a 2.5" lift on jkur? Most 2.5" lifts don't include them. I have read some manufacturers claim better articulation but do they really.
Take measurements on your Jeep to figure out the truth, as to whether or not its actually needed. If your axle is off centered more than half an inch, i would take an adjustable track bar into consideration.
Your choice... I purchased one for mine after I felt the Jeep wandered to much to let my wife and daughter drive. It drives like factory now... best $150 you can spend for "peace of mind". I say get it.
Articulation? Maybe a little. On one side. With the axles shifted you're most likely to feel a difference between hard left and hard right turns. Normal driving, you'll have a slight crab as you drive down the road, most noticeable by the car following you.
I guess I should ask how much shift makes a difference. I have seen stock jeeps off by 1/4" on the showroom floor so a 2.5" lift might actually be closer to centered the other way with the lift. If a 2.5" lift ends up being 3/16" off is it going to make a difference seat of the pants?
