Advice on installing Synergy rear trackbar ?
Hey guys any advice before doing this . Is it literally unbolt stock , bolt on synergy ?
I already have a bracket there that came with my Mopar lift but came across a great deal for the synergy rear trackbar and figured id get it. I was gonna just remove the stock , adjust synergy to the same length and then bolt back on . Will an alignment be needed after ?
Also does this adjust on the jeep or does it need to be removed everytime
Synergy's design allows you to adjust that while installed. You'd still want to be generally close to the correct length when you install it, but then you can tweak it either way if need be using their adjuster sleeve.
