Anti rock bars--
Anti rock bars--
I'm curious about anti rock bars from places like Currie and Teraflex
Are they just an alternative to quick disconnects (which i already have). Or do they actually provide something more. Do they help with street ride? Or just off road only?
I've read some folks say the jeep has more sway at highway speeds with anti rock bars, especially the rears?
Teraflex makes a dual rate sway bar system, but it's almost twice as much as a front..
Thanks
Steve
Thanks
Steve
Keeping the axle connected to the sway bars can give you better traction off road if they are properly sized. The aftermarket brands are designed to flex more thats the reason you don't need to disconnect. Street ride will see more body roll because the bars twist easier then the stock. Some arms will have multiple mounting points for the links which will allow you to "tune" the spring rate a bit on the bar. The farther out you mount the links the more flex you are going to get out of the say bar.
Teraflex has one that disconnects with a twist of a knob. It has a street setting then you turn a knob and you are free for offroad. It's pricy so you have to decide do you want to stay off the ground or do you mind being a bit dirty. I could only see doing it myself when I'm too old to do it manually.
Former Vendor
Unless your Jeep is off road centric, I'd steer clear of a performance sway bar for a street driven rig, the one possible exception is with a dialed coil over set up (which these Jeeps don't really need in the first place). Just get a set of disconnects on the factory bar, you'll be better off. The Teraflex bar does have some good reviews, although I don't have any person experience so I can't really say too much about it on a daily driver.
It's true that when properly dialed performance sway bar set up can totally rock off road, in my opinion the sacrifice you make on the street side isn't really worth it for a daily driver. While it's not like driving completely disconnected, it definitely does give you boatish handling on the street. It doesn't get you that much on the rocks with a conventional short arm system anyway. Where it really starts to shine is on long travel, more extreme set ups, where the additional stability makes a big difference. If you want a little better stability while disconnected, invest in some good gas shocks.
I went Antirock front and back. One of my best mods to day. It's SO stable in off camber situations and that floating felling is gone. Better traction, no body floating or leaning.
The rear system is also nice in that it routes your hard brake lines inside the frame.
On road is not horrible. Don't let that spook you out of buying a set. Love my Antirocks... would never change them.
