Anybody considering this radiator replacement? Flex-a-lite aluminum radiotor
stock radiators these days are plastic (!) and eventually crack - especially if vehicle is used offroad. that is why i am thinking of being premptive and having one of these installed. not sure it would in actuality be more reliable though... maybe others can weigh in.
I plan on going to this radiator when my stock needs replacing. Why? Crawling at altitude, you need all the surface area cooling and air you can get. Just general driving at 8k-12k feet will creep the temp gauge up to around 220-230. Add in crawling, and it climbs even higher. Having the extra surface area and manual fan would help a great deal. Engines don't cool off as well at altitude. There just isn't enough air molecules for the temp exchange to happen. The only combatting way? Improve flow and surface area. I've been holding off on PSC hood louver for this reason. I would rather apply the $160 toward the Flexalite set up, keep elements off my engine and have versatility in my cooling needs. Not to mention, in the dead of winter, I want heat under that hood. I actually saw the temp gauge drop a few times when we were snow shoeing, got back to the jeep, had the heat on full power and see the gauge drop quick.
This part is like no other. For most, the stock will work great. For some, they need something specific. Unless you have that need, for any mod, it's a waste of money.
