Sponsored by:
Sponsored by:
BFG All Terrain ride
Old 07-23-2008, 05:31 AM
Desert Fox's Avatar
Smile
I had a set of 33" on my TJ. I ran them at 24 psi. Good ride and not too noisy. I also ran them at 10 psi in the rocks. They are not all that good in the rocks. But, the best all around tire I ever had. They lasted for about 40,000 miles.
Old 07-23-2008, 06:07 AM
cmh2001's Avatar
I have been running this tire on various vehicles over the last five years. Its a really good highway ride and not bad off road.
Old 07-23-2008, 08:47 AM
LakeTravisJK's Avatar
imho... I like the C-load rated BFG AT's, but the E-rated have too stiff sidewalls for the JK. That in combo with the heavier weight made for an uncomfortable ride even with air pressure reduced 5psi.
Old 07-23-2008, 11:19 AM
seer1's Avatar
I'm running these and have ended up with the opposite effect. At first they were a bit rough of a ride. Not too loud, excellent off road, but kind of bouncy. I lowered the pressure to 30-32 or so and the ride improved. Then I put on the OME 2", Currie adj control arms FT adj trackbars and a D44 front axle and the handling really went downhill. I put on Spidertrax 1.5 spacers because the control arms are so stout (fat) that the uppers were rubbing on the rears and the handling improved greatly, but it still wasn't where I thought it should be. After a trail ride I filled to 42 psi and the handling was back to where I thought it should be and the ride is great. When I go 35's I'm sticking to the KM2's. Work with your tire pressure and how it reacts to your lift, etc and I think you will quickly come to love those tires.
Old 07-23-2008, 12:36 PM
08RedRecon's Avatar
Great tire, cant beat them
Old 07-23-2008, 12:40 PM
britjk's Avatar
I'm running 305 65 18 BFG All terrain KO's and I love them. No road noise. Smooth ride. I put Nitrogen in them at 35 lbs.
Old 07-23-2008, 12:46 PM
rjmcam's Avatar
Just because..
What did you pay for the Nitrogen and where did you get it done?
Old 07-23-2008, 12:54 PM
roguejk's Avatar
i have the 33"x 12.5 BFG KM2"s mud terrains and have the tires aired up to 25-3o psi (cant remember) and they are great the place i purchased them had them @ 40 psi and i felt every bump but aired down they are smoother and very lil road noise and as soon as these wear out im gonna get them in 35"s
Old 07-24-2008, 03:18 AM
britjk's Avatar
Originally Posted by rjmcam
Just because..
Around $15.00 for all four. They depressurize them and then refill them all at the same time. Refills are free if the tire pressure ever regulates. I got them done at Tire Kingdom.
Old 07-24-2008, 05:39 AM
Jeeper08's Avatar
Thanks Guy's, I will be ordering the BFG 285-70-17 KO's today. In this tire (All Terrain KO) the D rating is the lowest rated side wall I can get right?
Quick Reply: BFG All Terrain ride
