Sponsored by:
Sponsored by:
Broken Driveshaft
Old 10-26-2016, 08:44 AM
Chuck-The-Ripper's Avatar
Originally Posted by Monte417
I think there's a company that does that now. Can't remember who though. Twaton driveshafts or something
Yep. Tatton's driveline does it but any local shop should have no problem doing it as well. You would just more than likely have to supply the high-angle rzppa. I find it much easier to take care of problems if the seller is local rather than purchasing online/through the internet. Ive learned that the hard way, lol.
http://m.ebay.com/itm/251560419414?_mwBanner=1
Old 10-26-2016, 09:06 AM
kjeeper10's Avatar
Is that the TF rzeppa though ^^
JE reel is the other iirc and they use the high angle TF joint.
Old 10-26-2016, 09:12 AM
lkjk's Avatar
That looks like the stock rzeppa though, correct?
Old 10-26-2016, 09:14 AM
Ajkaz's Avatar
Tom Woods and Adams DS do not work the Rezeppa joints, I called to ask, if I could run a heavy duty Rezeppa joint shaft safely and gain a little caster back I definitely would.
Old 10-26-2016, 09:18 AM
lkjk's Avatar
I'm in the same boat, my stock rzeppa exploded driving a few weeks ago and I need to order a front DS, just haven't decided which although adams is up there.
Old 10-26-2016, 12:25 PM
Definitely looks like the teraflex to me. I don't own it so I can't say for certain. My guess would be the teraflex and they just don't want to give them the publicity lol.
ID:	659713   Click image for larger version
Old 10-26-2016, 01:50 PM
kjeeper10's Avatar
Thats my pic on right. Looks good to me ... Who whats to be the guinea pig?
Old 10-26-2016, 02:30 PM
DJ1
Former Member
DJ1's Avatar
From what I've seen, Teraflex right now is the only one with a front drive shaft to have high angle rzeppa's on both ends of the DS.
https://teraflex.com/shop_items/56fe...d70ed4933e4efe
It's $900 bucks though lol
For the price, that Tatton looks tempting as long as it has the high angle rzeppa on it...
Old 10-26-2016, 03:21 PM
Originally Posted by DJ1
From what I've seen, Teraflex right now is the only one with a front drive shaft to have high angle rzeppa's on both ends of the DS. https://teraflex.com/shop_items/56fe...d70ed4933e4efe It's $900 bucks though lol For the price, that Tatton looks tempting as long as it has the high angle rzeppa on it...
The tatton is a u-joint on the one side. I'm sure they would have no problem building one with them on both ends. I remember when I first started on jeep forums they were one of the big names.
Old 10-26-2016, 04:54 PM
TweakJK's Avatar
UHH you people are making this way harder than it needs to be.
You broke your slip yoke. Buy a new one for like $60. Spend 30 minutes installing it. Done. It literally just slides off. Put a new ujoint in the new one, slide the slip yoke onto the splined section of shaft, reattach the ujoint at the pinion yoke. Thats it.
There is no reason to take that into a shop and there is no reason to have it rebalanced, and there is certainly no reason to switch to a rzeppa joint.
Count your splines and slip length and find one that matches up. I feel like a lot of people dont realize that all driveshafts are made out of OEM parts that are all very standard.
http://www.dennysdriveshaft.com/c104...na_spicer.html
Quick Reply: Broken Driveshaft
