Caster vs pinion angle
The main thing I'm looking for is how little caster can you run and have "safe" handling at speeds up to 75mph. I have a rock krawler 3.5" lift 35's with a double cardan front drive shaft. After having new gears installed (spinning the shaft faster)I have notice more front drive shaft vibration. I believe my caster is around 5* currently. My diff side u joint appears to be at an angle 6-7*. If I change my caster to 2* to get my drive shaft closer to 3-4* is my steering going to be terrible. I'm thinking its smarter to have the drive line more correct than the steering but would love some input.
Thanks
Thanks
Thanks
Thanks
Dude, get her a caster corrected housing like I run. Your wife needs the Jeep to handle safely.
Edit: I thought you were my buddy Johan! His screen name is similar to yours. Sorry, I wasn't calling your Jeep your wife's jeep to be rude, his JK on 35" rubber is his wife's and he drives a Cherokee on 35" tires.
There is absolutely no reason to run 2 degrees of caster with 3.5" of lift. You should not be getting any vibes with a dc driveshaft with 4 degrees of caster. I have 3.5" of lift up front and run high 4 degree of caster with no vibes up to 95 mph. If you are still getting vibes with 4 degrees of caster your driveshaft is not balanced properly or you have a bent yoke
My Caster is currently at 2.9 and 2.5 after installing my Mopar 2in lift (3 1/8in lift in the front actual). I was going to increase the length of my front LCA's to increase the caster but the recommendation on this forum was that if I didn't feel any vibrations, it steered and drove fine, which it does, to leave it alone or get a caster correction housing if I wanted to chase after caster.
So I guess I can tell you that as low as 2.5deg of caster feels fine at 75MPH, because I drove over 500 miles on the highway on a trip and didn't feel anything abnormal. No pull, no drift, steering seems fine.
I appreciate the input. Scheduled an appointment for an alignment mon. I'll get some confirmation of where it is spec wise and go from there. I know the track bar needs some adjustment as well. The axle is about 3/4" more driver side.
No steering correction, yet. Gears are 4.56. The shop that did the lift didn't give me a alignment printout. I'm estimating using an angle finder. My vibrations seem to be limited to between 55-60 mph. It's not terrible but is noticeable. The jeep handles fine. Take your hands off the wheel at 60mph and tracks dead straight.
