Is Cracked Manifold covered by lifetime powertrain warranty?
My drivers side exhaust manifold cracked at 50,000 miles. I dont have an extended warranty.
Does any Emission or Lifetime powertrain warranty cover this? Anybody have any luck replacing it at the delearship?
Thanks! Brian
Thanks! Brian
Mike
Gasoline Engine: cylinder block and all internal
parts; cylinder head assemblies; timing case, timing
chain, timing belt, gears and sprockets; vibration
damper; oil pump; water pump and housing; intake
and exhaust manifolds; flywheel with starter ring
gear; core plugs; valve covers; oil pan; turbocharger
housing and internal parts; turbocharger wastegate
actuator; supercharger; serpentine belt tensioner;
seals and gaskets for listed components only.
