Currie Control Arms
Currie Control Arms
You know Currie did not give much instructions on installing there control arm's other than front and back. So I said to my self, "Just must be common sense with these zerk fitting I'll have to grease sooner or later." I've been messing with these things on,off and over... So today I said," I'll check the images on Google." and now I'm really confused. I have all the lock nuts up on the frame (not axles) ends right now and they seem pretty parrellel with the factory mounting tabs. Is this the right way?
The Johnny Joint end with jam nut go's to frame mount, grease zerks up. Make sure you grease the joints
Before install...
You can set and install lowers. Then use a jack to hold the diff where you want it. Adjust uppers out to align holes. Drop jack and re-measure angles.
Front +1-2°
Rear -2°
Most alignment shops wont deal with adj arms so ask the question before wasting $80
On the hunt for a alignment shop in my area and that will deal with all my undoings
