Cutting pinch seam
Sure, until you hit a large bump and your tires give you a little help.
Why the resistance to cutting it? Literally takes 5 minutes to prep and cut. 20 to JB Weld cleanly. A little sanding after it dries and then some color match touch up paint and it will look like it came that way. They actually come from the factory with it cut now. And really, all they do is stamp cut it. Nothing fancy.
Sure, until you hit a large bump and your tires give you a little help. Why the resistance to cutting it? Literally takes 5 minutes to prep and cut. 20 to JB Weld cleanly. A little sanding after it dries and then some color match touch up paint and it will look like it came that way. They actually come from the factory with it cut now. And really, all they do is stamp cut it. Nothing fancy.
Yeah mine seem to be cut from factory.
