D44 or PR44?????
I would start by checking the for sale sections on the forums there are at least 6 forums out there I know of that are for JK's or have a JK section. I see dana 30 axles all the time from people who swap out to D44's or larger. You may also check great lakes 4x4 as there are always tons of axles on there in your area. Just make sure you get the proper width and bolt pattern.
Sold mine for $400, and it took me a year to to it. It's not a very desirable axle. Still can't get rid of my rear.
I had it listed on every forum. Finally tossed it on CL and sold it to a guy two weeks ago for $700. So, not $600, but mine was like new, sleeved and gusseted. Stronger than the $2k axle you just bought and it would have bolted right up. I even offered in my listing to swap the axle for the buyer.
damn that is cheap. I know it would be smart since i don't know too much about wheeling or these axles to just stick to the original but in hindsight, i will be pissed next year when i wish i would have installed the d44. I think i will stick to the d44 and just keep reading forums and asking total newb questions. I appreciate all the feedback
Also, happy to lend a hand if you need help getting the axle on. Wouldn't take but a couple hours. You can drive it, we'd just leave the front driveshaft off until you get the rear regeared. I think you could technically leave it on (I forget...), but no sense in risking shifting into 4 wheel...
I'm pulling my Jeep apart at the start of Nov and will have switches and wiring for the e-locker for sale. I had a Sport and bought Rubi axles. A friend of mine is an electrical engineer in the auto industry and put together all the wiring. Also have the factory plugs, so it connects to the plugs on the axle. It would basically be plug and play to get your locker working. PM me if interested.
I went the pro rock route and I couldn't be happier
I don't think welding on gussets and such will get you close to the strength of the pro rock
But it doesn't sound like the OP really needs that much strength
Btw, I'm just over in southern Maine, where in New Hampshire?
I'd be more then happy to show you the pro rock and see what you have
Matthew
Matthew
Matthew
Matthew
As noted above, the housing on your new d44 is basically the same as the d30. Wouldn't be a bad idea to read as many housing upgrade threads as you can find so you can start forming an opinion on whether you want to add any reinforcement to it.
