Dana 30 axle shaft compatibility
So, I'm looking to buy a set of used axle shafts for my Dana 30 as spares. Nothing fancy, just something to toss in if I break one. No interest in better than OEM quality, as I want my axles to be the weakest link intensionally.
With that said, is there any reason a 27 spline Dana 30 Assembled axle shaft won't slide in the front of my JK? I've personally never tried it and would be interested in hearing from someone that has. I know there are minor differences in the various versions of the 30, for instance high vs low pinion. But I'm thinking the shafts haven't changed. Thanks in advance ladies and gents.
Yup, jtphoto JK is correct on all counts.
One caveat that I discovered is that the bigger yokes will sometimes rub the bolts that hold the wheel bearing hub assembly in place when you install the newer shafts (2012+) in an older axle (2007-2011). This is the case for both the D30 and D44 front axles.
