Dana 44 Swap
Dana 44 Swap
Hey guys, I have a quick question and was wondering if anyone has done something similar.
So back in high school I drove a 2000 ram 1500 4x4. I'm wanting to swap out the front 30 in my Jk and the old ram is rusted and about to be scrapped. Could I use this 44 and swap it in? It'd be rebuilt and geared but what else would I need to do this or is this a bad idea? Any opinions would be appreciated!
Never done it, but a few thoughts from reading other threads: That axle is low pinion instead of high like the stock jk front? Could be a problem. Make sure it can use a ratio that matches the rear. Find out the width difference and the lug pattern, probably need a set of wheel adapters. Fabricate rings to get the electronics working again? Cut all the brackets off, making sure that there is enough room for the jk brackets that you will be making?
You are probably better off reading a few junkyard threads and going with one of the d60's that people have already worked all that stuff out for.
Never done it, but a few thoughts from reading other threads: That axle is low pinion instead of high like the stock jk front? Could be a problem. Make sure it can use a ratio that matches the rear. Find out the width difference and the lug pattern, probably need a set of wheel adapters. Fabricate rings to get the electronics working again? Cut all the brackets off, making sure that there is enough room for the jk brackets that you will be making? You are probably better off reading a few junkyard threads and going with one of the d60's that people have already worked all that stuff out for.
A friend has a junk 2500 that has front and rear D60s and I thought about it but I'm not sure I'm ready to make a jump to 60s yet as that's going to add a sh*t ton to the build list.
I may end up just trying this 44 as a project since I already have it and go ahead and figure it all out before rebuilding it.
Unfortunately, people are not doing junkyard d44 swaps when they can do d60 swaps for about the same costs and amount of labor. Just doesn't make sense. Before you get too far along, check into the electronics (assuming you want all of your jeeps gauges and stuff to work?) But yeah, if I had the fab and setup skills I'd be all over a junkyard swap. I don't, so I bought.
Check out Polyperformance for their bracket kits.
Also I would highly recommend swapping out the rear axle as well to keep the same bolt pattern for front and rear wheels. I see no reason why you cannot. Most people going to 60's is for one of two reasons. First their buddies have them or second their wheeling demands the heavier duty axles.
Check out Polyperformance for their bracket kits. Also I would highly recommend swapping out the rear axle as well to keep the same bolt pattern for front and rear wheels. I see no reason why you cannot. Most people going to 60's is for one of two reasons. First their buddies have them or second their wheeling demands the heavier duty axles.
My wheeling isn't going to demand 60s at all and living in Carolina and Indiana it probably won't. I doubt I'll ever run anything over 37s and if I ever do it won't be on this rig or for many many years to come. I just don't see the need for 60s IMHO.
Bolt pattern on it is 5x5.5 so I may just get adapters. The rear end in the truck is a D60 that needs rebuilt so we'll see how the build looks for me first.
I believe the RAM has a front 3piece axle set with vacuum disengage (my 1998 did) .. Might want to check that out first. That's not a system I would want in my Jeep.
Bolt pattern and axle width. You would want the wheel adapters on the rear to make it the same as the from. The Ram axle is wider, adding adapter plates to that again will make the front much wider then the rear. Putting them on the rear will balance it out a bit better.
If you look under the front you will see the vacuum pot and lines on the diff tube. I believe there is a bypass system for the 3pce axle to permanently lock the 2 pce where the collar is.
