Do not install Detroit Soft Locker on 2012+ Jeep JK with automatic
Just a warning. This will cause 2012+ JK's to go into limp mode. I wanted to post this for others to save them some aggravation of having to learn this the hard way as I did. When I had mine installed in October I didnt find any drawbacks based on the research I did on the web. In fact I found most distributors listed them for sale for 07-13. It was a great locker and very streetable but unfortunately not compatible with 3.6 and automatic transmission.
Sponsoring Manufacturer
I am confused as to how a locker caused a Jeep to go into limp mode. Can you tell us exactly what caused it to go into limp mode? I guess I could see it MAYBE messing with abs operation but limp mode doesn't make any sense. Did you change anything else when you put the locker in?
No factory 3:73 and I have 2012 AEV Procal to adjust for tire size/speedometer. I have also since found one other thread that said they had the same issue. The gearing was the first thing I reconfirmed after install and it was definitely not changed. My diff shop said that he and I believe he said 4Wheel Parts Wholesaler (may have been 4Wheelers Supply) had done a few more since mine and and they all came back with same issue. I think something to do with the brake sensors and/new 5 speed auto trans.
