double triangulated rear end
I currently have the teraflex long arm kit but will be changing the rear to a double triangulated configuration. I have a few questions if anyone can help.
I am planning to reuse the lower arms and replace the large rubber bush with and adjustable rod end but I don't know what to order that will be the same dimensions as the teraflex joint, also will those arms be long enough? If not what length would be recommended. The other thing I'm not sure about is what size tube and rod ends should be used for the upper arms ?
Cheers
Cheers
