Dynatrac Prosteer Ball Joints
Results 1 to 6 of 6
  1. #1
    JK Jedi Hellbound13's Avatar
    Join Date
    Apr 2008
    Location
    Westchester, NY
    Posts
    4,470
    Default Dynatrac Prosteer Ball Joints
    So I called Dynatrac and they will have these ball joints available the middle of the month.
    However, they have only tested them on Dana 44 axles.
    Will the ball joints also fit a Dana 30?
    They said the stud is a little longer than stock, so they are worried that the top ball joint stud will hit the u joint on the Dana 30 but they also said if its the same clearance it should work. They just don't know cause they have no tested them on a 30.
    Anyone have any idea on this, how the 44 might differ from the 30 in regards to this?
    Also it seems silly if they want to sell these ball joints not to test them on a 30 as Im sure a lot of people who want them have an X or Sahara.
    2008 Rescue Green 2DR X
    Auto 3:73 gears
    255/75/17 Goodyear TripleTred on 17" Mountain Edition Wheels
    Tuff Stuff Hood Mount (Axe)
    Rancho 9000XL Shocks
    Bilstein 5100 SS
    PUREJEEP Bare Bonez Crawler Front Bumper
    PIAA Xtreme Whites Windshield Mounted
    Rugged Ridge Mirror Relocaters
    Smittybuilt GEAR Seat Covers
    River Raider Rock Rails
    Kilby Exhaust Skid
    Teraflex Adj. Lower Control Arms
    Currie Steering System
    Body Armor Tail Lamp Guards
  2. #2
    JK-Forum Founder
    Join Date
    Jul 2006
    Location
    Laguna Niguel, CA
    Posts
    36,531
    silly? i don't know, i had an opportunity to install a test set on my orange JK and turned it down because i felt that nobody would install a set of $600 ball joints on a dana 30
    having said that, i would imagine that these would work and as dynatrac said, the only issue would be one of clearance at the u-joint.
  3. #3
    Join Date
    Apr 2008
    Location
    Westchester, NY
    Posts
    4,470
    Quote Originally Posted by wayoflife View Post
    Why would no one install a set on a Dana 30? I don't need a whole new axle but I sure would like to have a set of ball joints I will never have to replace again..
    So you are saying they will press in fine but there is a clearance difference between to 30 and 44 at the u-joint?
    Auto 3:73 gears
    Bilstein 5100 SS
    Kilby Exhaust Skid
  4. #4
    JK-Forum Founder
    Join Date
    Jul 2006
    Location
    Laguna Niguel, CA
    Posts
    36,531
    Quote Originally Posted by Hellbound13 View Post
    i don't know, i guess most of the people i know are looking for a reason to upgrade to a dana 44 or 60
    yes. the knuckles on the 30 and the 44 are the same and these ball joints will press in just fine. the length of them is the concern but, i would imagine that they would fit and that dynatrac is just being cautious.
  5. #5
    Join Date
    Apr 2008
    Location
    Westchester, NY
    Posts
    4,470
    Yes they said they think they would fit but they did not want to sell me something that won't fit. They are hoping to test one in the future with a 30 and said to give a call back in a few weeks.
    I was just hoping they would fit as my ball joints are shot anyway and I do not want to replace with stock.
    Auto 3:73 gears
    Bilstein 5100 SS
    Kilby Exhaust Skid
  6. #6
    JK Enthusiast 0311sgt's Avatar
    Join Date
    Apr 2007
    Location
    York Pa
    Posts
    283
    If they want to try a set on a Dana 30 they can have my JK as test
    3 Inch BDS Lift
    35x12.5x16 Yokohama Geolander AT/S
    16x8 Cragar Soft 8 Black Steel Wheels
    Custom front Winch Bumper from RoundStar OffRoad
    Mopar Offroad Rear Bumper
    Oilpan/Tranny skid Plate by Skid Row
    JKS Quicker Disconnects
    Skyjacker Brake line extenders
    Skyjacker Adj Rear track bar
    High Clearance Adj Front Lower Control Arms by RocKrawler
    RocKrawler Front Lower Control Arm Mounting Bracket/Skid Plates
    Warrior Products Rear Safari Doors
    Plenty of ROCKRASH
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
