Sponsored by:
Sponsored by:
General Grabber X3
Old 12-25-2016, 05:10 AM
Pete1971's Avatar
Default General Grabber X3
Hello all and MERRY CHRISTMAS
quick question, gonna be needing tires for the JK looking at the general grabbers x3 does any one have experience with these ?
Old 12-25-2016, 05:18 AM
chemlight_ninja's Avatar
I have some master craft courser cts that look very similar. If the generals are anything like that master craft then its a fine tire on highway and off.
Old 12-25-2016, 05:19 AM
karls10jk's Avatar
They're new as of the fall and I was pretty close to ordering them (bought tires Friday!) but the extra 10-12lbs per corner in addition to the narrow tread kept me from them. They measure out very narrow in comparison to other tires- 10.5" in the 315mm size category.
They look awesome but I couldn't justify the extra weight with so little info on longevity.
Old 12-25-2016, 06:06 AM
Pete1971's Avatar
I was also looking at the General Grabber AT2's which are 7 pounds lighter in 285 than 295 X3's and I've read some good stuff on the at2's
gonna be mostly on road driving occasional back roads but we get a bit of snow here in the northeast also
Old 12-25-2016, 08:22 PM
BombJock's Avatar
Sorry, no experience with AT3s, but I have been running the Grabber for a couple years now. The wear nice and are not overly loud on the road. I will consider AT3 next time around.
One recommendation, run red letters in if you wheel it much. The red letters will wear off quickly and look like garbage over time. If I run them again, I will go red letters in.
Old 01-12-2017, 04:37 AM
Pete1971's Avatar
ok guess not much info on these, how about GENERAL tires in general have you guy's had good luck with them in all sorts of weather and terrain ?
Old 01-12-2017, 06:16 AM
rob_engineer's Avatar
I had general grabber at2 on a Mercury mountaineer. I had it for a while, then sold to a family member. By the time they were replaced they had over 100,000 miles on them. They held up great. Wore evenly. Were great in all NJ weather conditions on the road. I did not take this vehicle off road except easy fire trails.
Old 01-12-2017, 05:56 PM
Az scooter's Avatar
You can get them without red letters, and they are actually cheaper. I have the red letters, and people can tell my jeep does go off road.
As for General tires. I have had a fleet of 32 light duty trucks, from 150's to 350's. We have tried every major brand out there, including Michelin, since they are usually the gold standard. The Generals have given better tread life than them all, and have proven less prone to failures.
As for the grabbers on my jeep, I am super pleased with them. I bought them thinking that if they lasted 12k I would just get a new set. At this point, my jeep is at 20,000 miles in the past year. The Grabbers are wearing like Iron. I will be buying them again. That being said, I will admit that I bought Toyo A/T2's for my Raptor because I wanted something quieter on the highway,and it isn't used for what it is necessarily designed.
Old 01-14-2017, 06:38 AM
onlyone's Avatar
I just put them on my JK and so far they are very nice. Deep snow they are great. They are heavy but they are also larger than most "35's" that's probably where a lot of the weight it. Mine measure right at 34.5 give or take with 26 psi. That's what I used for my Procal and it's spot on. They are a good inch taller than my BFG KO2 35 12.50 17s that I had on my white JK.
Old 01-14-2017, 06:40 AM
onlyone's Avatar
Next to my BFG 34 10.50's
Quick Reply: General Grabber X3
