Help me figure out my squeak! Ahhhhhhh!!!
I have a squeak in the rear of my jeep. It's sounds like tweety bird chirping around when going over washboard roads badly. It doesn't really do it on flat roads. What I did find is that if I'm on flat road and I slightly press the brakes, just before I feel the brakes actually start to work, I get the shatter like chirping from the back of the jeep. If I apply the brakes further, the sound goes away.
It's crazy how one squeak can drive you to the point of selling it.
Must. Find. Fix.
Must. Find. Fix.
Must. Find. Fix.
Must. Find. Fix.
I had a real bad squeaking noise when on bumpy roads coming from the tailgate after I washed my Jeep...turns out, when I was cleaning the back seal area with a rag that had armor all on it...I got some in/on the latching mechanism, tried cleaning it with a dry cloth and it helped but, didn't go completely away for about a week or so when the armor all finally just wore off.
I just had this squeak. I'll save you guys some trouble. Mine would squeak once I got around 20-30 mph and would continue up to 70. It would get the worst when just tapping the brake. And would go away when harder on the brake. Put mine on a lift and ran it. Ended up being a bent axle shaft in my left rear. Was causing the brake caliper to move and squeak.
As the other guy said could be flange or bearings too. Try putting it on a lift and running it. That's what helped me narrow mine down. I ended up replacing/upgrading my rear axles left one was a bitch to get out because of the bend but that was the complete cause of the squeak for me.
