Sponsored by:
Sponsored by:
Honest question wheel adapter
Old 10-24-2016, 08:14 PM
Jasoncinpean's Avatar
Default Honest question wheel adapter
Before you guys roast and call me cheap.... 😂 just got ultimate 60s problem is I don't want to be dead buried in my axle crate boxes so I'm wondering anyone know if 5x5 to 8x6.5 wheel adapters will work with these axles? Ppl say stuff about a 2 piece adapter or something? Any help is appreciated
Old 10-24-2016, 08:23 PM
Chuck-The-Ripper's Avatar
http://www.pirate4x4.com/forum/axles...5858?_k=tlzsxx
Old 10-24-2016, 08:34 PM
Originally Posted by Chuck-The-Ripper
it said bad request....
I've searched the topic ppl say stuff about bore size not matching I'm so confused
I found a 5x5to 8x6.5 adapter that's also a 2 inch spacer wondering if that would work
Old 10-24-2016, 09:09 PM
Actually question is... is there such thing as an adapter to make my 8 lug axles fit my 5 lug rims? lol
Old 10-25-2016, 02:49 AM
karls10jk's Avatar
If you want to buy it then someone is making it. With the conversion that you'll have, yes- it will be a two piece system. The first will bolt to your 8 lug and then there is a cover plate (basically) that contains your 5 lug pattern that gets bolted to the 8 lug piece.
Looks to be these are the guys to have a set built for you.
https://www.motorsport-tech.com/wheel_adapters.html
Old 10-25-2016, 07:29 AM
If you want to buy it then someone is making it. With the conversion that you'll have, yes- it will be a two piece system. The first will bolt to your 8 lug and then there is a cover plate (basically) that contains your 5 lug pattern that gets bolted to the 8 lug piece. Looks to be these are the guys to have a set built for you. https://www.motorsport-tech.com/wheel_adapters.html
thanks man, now the only issue is figuring out how far the hubs stick out on front and rear I don't have my axles yet.... dang it if anyone knows how far they stick out chime in thanks
Old 10-25-2016, 07:59 AM
Invest2m4's Avatar
So, the 2 piece design can work. However, there is a lot of hub to clear and the wheel bore will be too large for a JK wheel. Your 69" wide axles are going to become insanely wide. Basically, I don't see it working and I definitely wouldn't run it on the street that way. A lot of the funky designs you see are used on trail rigs, not daily drivers.
That all said, 8x6.5 is a really popular bolt pattern. Buy some used wheels and you are good to go.
Btw, the wheel bore needs to be 4.96". You'd need a really wide adapter in the rear.
Old 10-26-2016, 07:54 AM
Originally Posted by Invest2m4
So, the 2 piece design can work. However, there is a lot of hub to clear and the wheel bore will be too large for a JK wheel. Your 69" wide axles are going to become insanely wide. Basically, I don't see it working and I definitely wouldn't run it on the street that way. A lot of the funky designs you see are used on trail rigs, not daily drivers. That all said, 8x6.5 is a really popular bolt pattern. Buy some used wheels and you are good to go. Btw, the wheel bore needs to be 4.96". You'd need a really wide adapter in the rear.
Thanks I decided to just find some 8 lugs and do it right. All run these till I buy some beadlocks. Thanks! I of course need to mount my 40s on them and get rid of those 35s that came with the wheels lol
Old 10-27-2016, 08:55 AM
Former Vendor
ReadyToMount's Avatar
We sell adapters and I have personally ran them. I think they are a good fit in some cases (1.5" max). OE wheels after a lift and larger tire. I am not a fan of trying to hard to make something work. The adapters are out there and if used properly are safe. Once you get to a 2 piece adapter you are now talking a couple to few hundred dollars. That eats up the savings of using wheels you have. It also pushes the wheels out at least another 2 inches which can look cool in some instances, but adds stress to the components at the ends of your axles. All that said I would think the better results would come from taking the money you would spend on adapters towards a proper fitting set of wheels.
Hope this helps. Can you do it yes. Should you do it. Maybe
Quick Reply: Honest question wheel adapter
