I got some really bad advice here...
I had a thread about shocks and trying to make my ride smoother and many here suggested that instead of putting softer shocks on my car to lower the PSI in my tires to softer up the ride.
I did that, but the only problem is that the tire treads that were almost at 100% are now almost down to the bone and now need replacing.
Just for future reference, do NOT flatten your Mud Tires while driving on the road. Keep them at the full company specified requirements.
They are there for a reason. I now have to get new MT's and even used ones wont be cheap.
That's why you are suppose to do a chalk test and run accordingly. Manufacture specs aren't correct as different jeeps weigh differently etc. A proper chalk test will give you the best even wear possible.
Curious what PSI were you running?
Nobody even mentioned a chalk test. I have the rubicon set-ups and I run them with 37 psi usually but I went down to 30 to make the ride softer. I was a bit softer on hard bumps but the ride was still wobbly and the Jeep is all over the place still like I'm riding a bull.
I put about 4k miles on them since changing the air pressure as I'm using my vehicle for a ride haring service. (Lyft, Uber)
It definitely isn't your tire pressure that wore out your tires. You got bigger issues then tire pressure if your all over the road and wore a set of tires out in 4k. 30 psi is not a problem.
Well everytime I try to address the issue people just say "Jeeps are just bumpy"
Attachment 547638
gone
Attachment 547638
gone
