issue with Plush Ride Lift JK Coil Springs by EVO MFG
1 Post
thanks all for your replies
I did change the coils to the driver side and the issue moved to driver side.
Andrew Perle from EVO MFG replied if switched left to right and have the opposite height and said it is interesting.
he asked if i did check the springs and were same length and update him.
I did it yesterday and found rear springs not having the same length.
front were having same length.
replied to him and waiting now.
1 Post
I prefer waiting for EVO reply and confirmation because i am not in hurry .. still hot for desert offroading here and we are testing different springs with fox 2.5 adj bypass shocks and waiting for the release of king 2.5 bypass for JK which will be in less than 1 month to announce the best setup for members in JK Club.
1 Post
In the right picture you hand is extended or looks to be extended a lot more so than the one on the left.
Can you get a measuring tape out and take a pic of the difference? Have you called EVO and asked?
I'm thinking of the 4 inch plush EVO coils but not if this is an issue.
Op- are you comparing the height of the evo coils against what you had with the Tera flex 4" coils? Or swapping the evo coils from side to side?
Evo does not have designated driver or passenger coils, they are the same coil for the front.
But they do make 3" or 4" coils.
front both are same but rear are not.
1 Post
when asked to get the measurement they were already replaced with the teraflex springs after a test drive with EVO.
