JK Forum Launches How-To Tuesday, Just for You
Sometimes bringing those great modification ideas to life requires a little help, which is why the team at JK Forum has launched How-To Tuesdays.
Read the rest on the JK Forum homepage. >>
Cool idea, but when did an ARB compressor sell for $80? The one in your photo is $500.
EDIT:
"Adding an air compressor under the hood may not change the looks of your Jeep, but it is the most beneficial modification on this list. This $80 compressor allows you to add air or get rid of air from the tires, depending on your off-roading needs. So if you need to get rid of air to do some sand dune off-roading, you can feel free to do so knowing you will be able to fill it back with air for the drive home."
EDIT:
And where can I find these $50 LED headlight upgrade bulbs?
Jeep Wrangler JK 2007-present Top 5 Inexpensive Modifications - Jk-Forum
Especially since one of your earlier posts said they were $150-200.
Jeep Wrangler JK 2007 to Present Headlight Bulb Modification - Jk-Forum
And where can I find these $50 LED headlight upgrade bulbs? Jeep Wrangler JK 2007-present Top 5 Inexpensive Modifications - Jk-Forum Especially since one of your earlier posts said they were $150-200. Jeep Wrangler JK 2007 to Present Headlight Bulb Modification - Jk-Forum
