JK Lift: AEV 2.5 and Correction Brackets, 35x11.5
My son just bought a 2015 JK Rubicon Hardrock M6. He wants to run the AEV 2.5 and 35x11.5R17 on Stock Rims. Adding to the suspension, he'd wants to do geometry correction brackets. Rounding out with a new Fox Steering stabalzer.
Should he just buy the AEV correction brackets or another brand?
We'll put in the metal cloak bump stops bumpers and adjust overall bumpstop height as needed (if needed).
Anything we should look out for with this setup? Current setup is 100% stock suspension with 126k miles.
In all honesty, the Fox stabilizer is not needed. For that particular component, the wimpiest little thing like the factory unit is perfectly fine. People tend to want to cover up any little feedback in the steering system and try to "tighten" things up. Me personally, when there is an issue, I want to know ASAP. If there is feedback in the steering system, there is an issue to address. Just food for thought.
When it comes to correction brackets, they all do the same thing. Some of the cheaper options will only have 1 relocation hole to use, but most of them will have 3 mounting positions. If you spend a little more for something like the Rancho model, the 1-piece design is nice and less cumbersome to install. Geometry brackets will always be an item that has good resale value to. keep that in mind.
With 35s on factory wheels you are going to need to run wheel adapters. Just FYI if you didn't already know. The 6.25" BS on a factory wheel won't be enough.
