Lift for Chains?
Lift for Chains?
I read recently someone that tried to put chains on their JK but they would only fit in the front. Does anyone know what kind of lift or backspacing would be necessary to put chains on all four wheels of a JK 4 door Rubi? Just planning the 'to-do' list when I finally pick mine up in 2 months or so... :-)
Thanks!
js.
Thanks!
js.
I had the post about the rear chains rubbing the upper control arms. This was on a 2dr rubicon with stock tires & rims. There is only 1 inch of clearance between the tire and the control arm on the back and I run a heavy duty set of 9/32" chains that the links are 1.1" wide. Problem will go away when I swap tires & rims and expect to gain almost an inch of clearance. Just not sure when the budget can afford the swap. As a side note I didn't have any problems with the chains on the front.
Thanks for the reply!
js.
