Lift Kit
Getting ready to do the same lift but don't want to get rid of my custom wheels, BS is 5.51" so I just added 1.5" hubcentric spacers. I'm going to run these spacers a month or so before the lift just to see if I can trust them, read so many second hand negative comments about spacers but only good 1st hand reviews if installed and maintained correctly. I like the look of the wider stance and the way the tires stick out just past the fenders now too.
I installed this lift with stock wheels and tires (Sahara 18in). It was recommended that the rear sway bar links be mounted inwards to allow for additional clearance. I did mount my links inboard, however it didn't really appear to add clearance due to the mounting stud on the lower.
I guess just be aware of this and check before bolting everything up.
