Sponsored by:
Sponsored by:
Lift kit with 35" tires, how low can I go?
Old 06-27-2011, 02:23 PM
JEP THNG's Avatar
Default info:
To the OP, here is a bumper comparison:
https://www.jk-forum.com/showthread.p...per+comparison
and you should read the sticky at the top of the modified section...great info on mods.
Old 07-05-2011, 11:01 AM
mumbling1's Avatar
Default Lift Installed / 35's on
Installed my 2" lift and my 35" KM2's fit great.
I only have a rubbing issue at full turn on the crappy plastic airdam in front. That'll come off as soon as I get a chance.
Old 07-05-2011, 11:11 AM
speed2005's Avatar
just get a 2.5 inch lift...it's perfect.
I was VERRY reluctant to do it, but I am happy with the result.
Check out the link in my sig for many pics
Old 07-05-2011, 11:32 AM
Biginboca's Avatar
If you can run 35's with no lift and flat fenders, would that mean you can run 37's with 2.5" lift and flat fenders?
Old 07-05-2011, 11:55 AM
Merlin4979's Avatar
Yes...well, sort-of. Check the Planman's thread:
https://www.jk-forum.com/forums/show...uspension-lift.
Old 07-05-2011, 12:32 PM
sick jk's Avatar
I have a 2.5" lift with 35" km2 tires. I also have bushwacker flat fenders. I have no rubbing issues at all. You will need a 4.5 backspacing. Here's some pics.
ID:	178550   Click image for larger version
ID:	178551   Click image for larger version
ID:	178552   Click image for larger version
Old 07-09-2011, 05:35 PM
Kodes01's Avatar
I'm fairly certain you the only thing stopping a stock jeep from running 35's are the fender flairs and your backspacing with stock rims, so you can do flat fenders or a cheap budget boost to give you a few inches or a body lift and fire on some 1.5" wheel spacers to finish it off
Old 07-09-2011, 06:05 PM
Levi's Avatar
I sky my 35's with 4.25 total lift. I'm getting 37's next time.Click image for larger version
Name:	JK doors off lifted.jpg
Old 07-09-2011, 07:03 PM
08UnlimitedSahara810's Avatar
I have the TF2.5" BB with Bushwacker flat flares. I just went to 35's yesterday and have no issues whatsoever.
Old 07-10-2011, 05:21 AM
Coley's Avatar
I did TF 2.5" coil lift and fits my 35.25" Rockers with no rubbing at full flex
Quick Reply: Lift kit with 35" tires, how low can I go?
