Lift Kit for Looks Only
#22
So if money wasn't an option; then what would be your recommendation for a lift?
Picture of my Jeep:
Attachment 610248
Picture of my Jeep:
Attachment 610248
#23
Pretty much every spacer lift is going to be the same. Essentially it is a 2" puck of polyurethane so there isn't much if any difference from manufacturer to manufacturer. The issue he was having is mainly involved with caster being too low. So if you get a spacer lift, look into drop brackets and maybe longer shocks. Those two items along with some longer rear sway bar links and moving the longer rears to the front will correct the geometry issues and the ride handling problems that come into play when lifting a jeep. The shocks aren't necessary but the correction brackets are going to definitely help.
